baxi 105e c/h temp sensor replacing
2 Dec 2010
Lincolnshire
I am going to replace the central heating temperature sensor in my baxi combi 105e instant boiler.
Will I need to drain the boiler first or can the replacement be done without draining it.
Thank you.
No and Yes It is dry pocket ,smear the sensor end with heat sink paste.
Thanks Baxmax but I'm not a plumber so I'm a bit confused. Am I right to think that 'No' I don't have to drain the system but 'Yes' I should use the heat sink paste?
I've never heard of this paste. Is its job to ensure a good contact, or what? What happens if I don't use the paste?
No drain down required and the heat sensing paste has conducting properties which allows the sensor to detect temp rise and fall accurately and is essential.Can be purchased in small tubes from heating merchants.No need to overtighten the sensor.
Will I need to drain the boiler first ...................NO It Is Dry Pocket
or can the replacement be done without draining it.................YES
Heat sink paste is self explanitory Simples......
thanks to both Baxmax and 45yearsagasman. i have now replaced the temperature sensor. i hope that solves at least one of the problems i have with my boiler. bloody baxi crap.
A well maintained 105e is actually a good boiler IMO and you haven't said why you are replacing the sensor.
I have had my boiler for about 5 years. I have had to have the seals connecting the internal pipeworks to the primary heat exchanger replaced (both the large and very narrow pipes). I have had to have the mechanism above the diverter valve replaced (I can't remember its name). the washers on the connections of pipework at the (nearly inaccessible) rear of the boiler have recently had to be replaced. the pressure release valve has, it seems, been slowly leaking from the time the boiler was installed - I only realised recently when it began to leak so freely that an icicle formed at the end of the pipe in the cold weather. after I replaced the prv (with help from the good people of diynot) the unexplained pressure drops stopped. I have just replaced the c/h temp sensor because the 80degree light kept flashing. and my plumber has told me that the diverter valve needs replacing. I should say that my present plumber is not the one that installed the boiler.
I don't get a chance to have the boiler serviced - I'm too busy (and skint) getting the broken bits fixed.
so yes, bloody crap is the politest phrase I can think of. but maybe I've just got a 'bad apple'. what do other people think?
