Baxi 105e Combi Boiler Hot Water Startup not happening for upstairs shower and taps. I need to get it started by having shower running and then starting hot water at downstairs tap. Boiler then it fires up, I switch off downstairs tap and shower works fine. This only started recently after I had turned the water into the house off at mains. I thought the problem was because I hadn't fully opened the waters mains tap when turned back on because initially after opening fully, the upstairs hot water seemed OK, didn't last though and back to same problem next day. I assume this is a water pressure problem, but possibly caused by a fault on the Hot Water sensor/microswitch. I actually have a spare sensor/microswitch cos I had to replace the Central Heating one some years ago when the opposite was happening, the central heating didn't fire up after requesting hot water. Replacing the Central Heating sensor/microswitch fixed that. Could this be the hot water sensor/microswitch or is this a water pressure problem and if water pressure need advice how to fix? Any advice appreciated.
Dave Stewardson, Mobile 07795617859
