Baxi 105e combi boiler
22 Dec 2012
Cheshire
Pressure from the boiler should be higher ((i think) is there a filter which could be blocked or a flow restricter which could have its flow rate increased. Thanks the make of the boiler is baxi 105he.
Measure the flow rate into a known container and if its as per manufacturers data then its working as it should. Increasing the flow rate will reduce the water temp.
