Hi
I have a baxi 105e the problem i have is a constant build up of air the the pump resulting in a 60 fault.
My plumber has tried a few things 1st swapped the pump 2nd changed the aav 3rd Fitted a magna clean, cleaning, flushing and inhibitor but I still have the problem. If I open the screw on the front of the pump when the fault happens I hear a hiss of air and then all if fine for a bit, I don't even need to reset the boiler. I have checked and bled all the radiators a few times but there is no air in them,
Last year I had the pcb, gas valve, both diaphragms and thermisotors changed over.
Having spent so much money on it I'm determined to get this problem fixed.
Any ideas please
Any ideas please
