Hi
I have a Baxi 105e (pile of pap) boiler. Water is leaking from one of the grub screws that connect the diverter manifold to the Pressure differential valve. Its only dripping but if I increase the pressure by adding water to the system then the dripping increases, Im having to top the pressure up every day as there is too much water leaking. I fitted a new diaphram to the Pressure differential valve recently, adding silicon grease etc. I dont have anything else I could comment on other then the water is off coloured suggesting that its from the CH. What could the problem be and how can I fix it Cheers.
