Baxi 105e Fan/Flue fault
20 Feb 2020
I have a Baxi 105e with flashing 50 which indicates fan or flue fault, the pump is spinning and the fan spins fine when calling for heating but the boiler doesn’t light, I have changed the air pressure switch but still no joy. I’ve read a lot about the pcb going as a common issue when this fault is active but the fan is normally not spinning it said articles. Any ideas before we go down the pcb route?
