How do I take the front cover off a Baxi 105E to get to the DHW diaphragm valve? The large panel appears to be hooked over two pins at the top, but what else do I remove to release it? Thanks
Thankyou very much for your help - job done, diaphragm replaced and hot water restored. I always like to make sure how to do a job properly before starting it!
