Hi all.
Spent some time in this forum trying to find the solution for this problem and got many tips, but the boiler is not working properly.
When I first noticed the water sandwich the pressure was below 1. Managed to fill it up, and the meter was increasing really quick but slowly going back after I close the tap. So I did it a few times until I reached 1.5.
Other thought was that the water temperature was too high, I don't know boilers that much but I believe I should be able to use that in the highest without any issue. Anyway, was keeping it under 50% and the shower was working fine for a while. Now it's happening again. Pressure is fine.
It gets warm and the indicator lights go over 80 and that's when the boiler turns off giving me the wonderful cold water, and goes back on again soon after.
Any other suggestions I could do/inspect by myself?
Can it be air in the system?
Thank you.
Thank you.
