When hot water is required the boiler fires up as normal. It heats up to the maximum 80 degrees and runs for 5 seconds or so before the flame goes out (DHW light remains on). The boiler then cools to 60 degrees before firing up again. This on off cycle then continues as long a tap is open. It also makes no diference where the DHW temp knob is positioned. The boiler is 6 years old and has worked fine apart from needing a circuit board 3 years ago.
Any ideas?
Any ideas?
