This looks like a regular problem from what I've seen on here. Our Baxi 105e heats downstairs DHW to over 55deg C but upstairs is only about 32deg C. Very surprising as both are teed together from presumably a common outlet. The boiler is downstairs in an attached garage. From what I've seen on her the first port of call is to change a diaphragm, so I have ordered a kit part no 5111137. Are there any details available on how to change? I can't see anything in the Baxi Manual, unless it is contained in a larger assembly. Thanks
