I had a Baxi 105e Instant installed three years ago, and up until now has caused me no problems. The problem i am currently experiencing is with the DHW. Sometimes when the DHW is called for, it supplies Hot water immediatly and yet in another instant it will run cold and the DHW will not function. Having spoken to a to Baxi, i explained that i have been guilty of using the Pre - Heat function which has been set to 3/4, to which they told me this function should not really be used, so now i have switched it off. The Central Heating system is working fine. I've also noticed that when calling for DHW and it runs cold, if i then operate the pre - heat function the DHW will operate and Warmish water will flow, but not Hot. During this operation, if i was to turn pre - heat back to zero the warmish water will stop and im left with cold water again. CAN ANYONE Suggest any procedures, or is it a case of a knackered component. Reading the fault finding page at the rear of the book sugests a pcb problem, but your the experts. I would very much appreciate any comments or feedback . Thanks, and i hope ive made sense. All the best Mark
