The hot water neon remains on after demand for hot water has ceased. There are no dripping taps or anything that could be calling for the hot water supply.
When it stays on, it obviously prevents the central heating from functioning, even though the boiler is not actually fired up when the neon is illuminated, other than when there is a real demand for hot water, such as a hot water tap being run.
After the hot water has been run, the hot water neon sometimes goes off, thus allowing the central heating to fire up, with its associated neon then glowing.
Our Corgi man struggled to find an answer and thought it was the temperature sensor, so he changed it. However, not long after he'd gone, the same problem returned.
Any ideas as to why the hot water neon would be on when the boiler's not even running (for hot water or central heating) and why it would then go off (although I guess it should do!) after a tap has been run - but only sometimes?!
Baxi, themselves, seem puzzled but have offered no solution.
Any help would be appreciated!
Thanks a lot.
Thanks a lot.
