BAXI 105e - leak from Pressure Differential Assembly??
28 May 2007
Gloucestershire
Hi
As always seems to be the case, I discovered a leak from the central nut of the Pressure Differential Assembly at 5 O'clock on Friday evening of a Bank Holiday Weekend!!
Having googled extensively, it seems that the entire Hydraulic Outlet assembly is usually sold as one item, albeit in two pieces.
My question is this. Is the leak symptomatic of a failure of the entire unit or should I just replace the Pressure Differential Assembly?
Thanks in anticipation
matspart3
You just need to buy a diaphragm kit for this and you will get a new seal 'o' ring that goes around the pin that ops out when the taps are turned on. Easy to remove front of diaphragm housing on these and replace. Isolate ch valves under boiler and cold inlet, drain boiler via built in drain point, NOT prv and replace. ;)
If its the usual gland at the front left which operates the switch its a common part to leak slightly but usually just enough to make a few drips.
The gland itself can easily be changed and will cost about £10 to supply.
Its relatively easy to fit but we charge a fixed price diagnostic fee which includes a service but this is one of the easier jobs for us. We normally carry the part as its such a common problem.
Tony
:rolleyes:
As I remember this is a ready formed gland that has no replaceable "O" ring.
Tony
The last kit I fitted about 3 weeks ago had the v small seal in it as well. Turned out the diaphragm had perished as well but for some reason the hot water had not yet failed.
I find it less time and a lot less fiddly if you just replace it
two little nuts and a retaining clip
job done
You get the pretty bits. The green ones are pre-pressed together.
Dave - am I more senile than I thought - I don't remember having to drain the primary water, just the tap water...? :confused:
no wonder you come across plenty of leaking isolation valves if your turning them off when there is no need too.......... :rolleyes:
Sorry...been at the stupid pills again!
£5.50 replacement diaphragm kit and selection of spanners in hand!!
Can you just confirm that I can remove the diaphragm housing cover with the valve in situ? There seems little point in removing the assembly unless I actually have to. I'm assuming I can replace the bits I need to from 'this' side...
