noticed my boiler only producing luke warm water when using the shpwer/bath or bathroom sink tap.
after some trouble shooting ive found that if any tap or shower is on full blast i only get luke warm water around 50 degrees and it wont get any hotter, if i reduce flow rate to around half the temp suddenly shoots up to full and maintains it no problem, then if tap is turned up again the temp drops back off.
even with the water temp dial on the boiler switched to full i still get the problem, obviosuly something to do with the extra flow rate and the boiling not being able to produce the hot water but no idea what would be causing it and how i can rectify it.
have looked through the baxi manual but cant find anything specifically pinpointing this problem, any help appreciated !! thanks
