Hello,
I have a Baxi 105e which stopped working. I called out a plumber who advised me that the boiler needed a new PCB and Extractor Fan and it was a very common fault on these models. I bought the new items and fitted them. The pcb was slight different setup to the original, which I believe you can't get anymore. I bought this one http://www.ebay.co.uk/itm/131279675620?_trksid=p2060778.m2749.l2649&ssPageName=STRK:MEBIDX:IT
The hot water now works fine but the central heating does not switch on. I have checked that the room thermostat is closing the 240v circuit and it is. I have also checked that the black wires out of the timer switch continuity when the heating should be on and that seems fine too.
I'm not sure what to check from here? Can anyone help please? I guess the new board could be faulty...?
