Help anyone my baxi combi 105e has stopped working the CH side is fine but there is no hot water I have tracked this to a problem with the diaphragm using the fault finding manual. When set to hotwater only The actuator on the diverter valve only works if i manually press the switch on the diverter valve my problem is there is a diaphragm in each valve which needs changing or could it be something else any help appreciated
