- Joined
- 2 Aug 2015
- Messages
- 18
- Reaction score
- 0
- Country
Hi all,
***post updated - again - Perhaps it's time for a new thread? - Latest Summary of issues:
This thread has been started on request as my boiler is now showing a warning light so hopefully this narrows the problem down.
I seen on this forum that the thermistor is a cheap part I may be able to replace myself, and that it can be checked by switching the sensor (or the wiring) with the CH sensor as they are both the same.
I can see what I think is the HW sensor in a pipe on the bottom left of the boiler - no idea where the CH one is though.
Are there any other checks I can do, I have a multimeter I can test the sensor with, but don't know the values I'm looking for.
- At all times CH is fine - if the CH is running and I turn a tap on, the flame shuts down.
- Day 1 - No ignition on HW side - primary flow microswitch tripped by diaphram fine and pump runs, pump proving switch tripped fine, - but no flame.
- Called company whose sticker is on boiler, they agree to attend to service it on day 3.
- Day 2 - Wake up to a warning light "HW thermistor fault" - HW does nothing, doesn't even run the pump. I start this thread to find out more about replacing the thermistor.
- Day 3 - AM - Wake up to HW magically working. Thermistor fault light went out over night.
- Day 3 PM - Nice bloke attends and services the (at this stage magically working) boiler. Tells me the water temp is fluctuating a bit, probably because the HEX gunked up - this makes sense. HW still working when nice bloke leaves.
- I go to have a shower about 4 hrs later and same fault as Day 1 reoccurs. No ignition on HW side despite both microswitches being tripped and pump running.
- Day 4 - No change - still no ignition on HW side - Latest update made (incl this list).
