- Joined
- 2 Aug 2015
- Messages
- 18
- Reaction score
- 0
- Country
Evening all,
I've reluctantly posted this as a google search of your forum has suggested (several times) that if I have no HW, then the most probable answer is that the change over valve diaphragm or microswitch is broken.
I'm a reasonably competent DIYer and have done the usual stuff (fixing minor plumbing leaks, oven element replacement, washer belts and washer motor bearing and brushes etc), so, I have hope that this will be easy(ish) to fix with hand tools and a bit of patience.
After reading many threads on here - I've had a look and can't see an issue with either the diaphragm or the microswitches. I wonder if the fault lies somewhere else, or (most likely) I'm missing something - grateful for any help.
Apologies for the long post, I've tried to give as good an explaination of the fault as I can.
Symptoms are:
So my questions are:
(i) Why is my DHW not working (obviously!)?
(ii) What does the "rear" switch do? Is it safe to connect the terminals (via two spade connectors soldered to a short piece of wire) to test it?
(iii) Am I barking up the wrong tree and the answer is still the diaphragm, for some reason I don't understand.
Thank you for your patience getting to the end of this mammoth post. Any advice you have would be greatly appreciated.
Steve
Symptoms are:
- Sudden DHW failure, no previous symptoms I am aware of;
- CH works fine;
- The boiler does not light after I open a HW tap;
- Pressure is 2 bar;
- Boiler reset seveal times using the dial, switching off the mains power, and one followed by the other;
- Green LED with "tap" symbol lights up when a tap is open; and
- No fault lights.
(A) Change over valve diaphragm rod visual inspection:
I have seem a diagram of this part in this thread:
//www.diynot.com/diy/threads/hello-baxi-105e-dripping-water.71801/
I'm confused as to why manual operation of the front microswitch doesn't prompt the boiler to light, and wonder whether the rear switch is faulty (I don't know what it does)?- Checked the rod extends when a HW tap is opened (it does);
- Checked that the rod extends far enough to operate the microswitch (it does); and
- Checked for leaks around the gland nut (no leak).
- The switch I'm referring to as the "front" microswitch is the one pictured in that diagram.
- The switch I'm referring to as the "rear" microswitch is mounted above the orange part in that diagram, and actuated by a rod protruding upwards when a HW tap is running.
Tests:
- Front microswitch operated by hand - no water running. This results in a pumping sound but no ignition of the boiler. A rod rises up and operates the "rear" microswitch.
- Rear microswitch only operated by hand - no water running. Nothing happens.
- Front and rear microswitches operated by rod (e.g HW tap open). Same result as above, i.e. pumping sound, but no ignition.
Steve
