please will somebody help?
i have a Baxi 105e which is not working at the moment. It is only 16 months old !
originally it started to cut out with the neon warning light above the 50 degrees flashing which suggests problems with fan or external flue.
the installation manual says to got to section E and check external flue, pressure switch, and venturi. all of these have been checked and replaced.
the boiler now fails to fire up at all when turning HW & CH and the above warning light comes on after about 5 seconds every time. this is the only warning light that comes on if this helps so we assume we dont need a new pcb.
can anybody suggest anything else to try who may have had similar problems.
