I have a baxi 105e boiler installed approx 2 years ago and since its installation I have had no end of problems attempting to resolve its gradual low pressure problem - as time has progressed the problem has slowly but surely become worse to the point where if I switch the boiler off over night i'm presented with a 0 pressure gauge reading in the morning. If I isolate the CH side of the boiler when the pressure seems to be normal at around 2 Bar and switch over to HW only and leave overnight, the pressure remains stable but as soon as I open both CH stop valves [return and flow] the pressure immiedietly drops to 0 bar. Rightly or wrongly I assumed that there was a leak on my CH system but having carried out a full inspection of the pipework/joints etc this doesn't seem to be the case. I even tried checking at high temp / switching off and also checking whilst cold to see if expansion and contraction of the pipework had any affect - all to no avail. In my view the water must be going somewhere but there are no obvious signs eg damp patches on the ceilings or walls. In operation if I pressurize via the loop to 1Bar with the CH on the pressure rises to approx 2.5Bar before dropping back to approx 1.5 - 2 Bar which according to the Baxi literature is OK. When the CH is turned off and the water cooled down the pressure drops slowly down to '0' once again. I have noticed a very small amount of water [a few drops] being emitted via the PRV while at the higher operating pressure but not enough to warrant the amount of water that I need to re-pressurize the system. I would appreciate any advice or recommendations. [Hair loss suffering]
