Where do I start........!?
Had a radiator spring a leak earlier this year....replaced and fitter set pressure at about 3 bar...which I thought a bit high...so he did drain a bit off. Noticed not long after that the overflow was dripping outside... Someone suggested turning the fill-loop valves off (has been sitting with one off and one on since boiler was installed)... This seemed to cure the drip...but a couple of days later all the pressure was lost.... Returned the fill-up valves to one on/one off, added about a bar of pressure, during use went up to just under 3....but the drip was back. At this point I resolved to call an engineer...(but havent...yet)!
Last night turned the heating on for the first time in a couple of weeks and the boiler started making lots of noise, the bar pressure was off the scale!
Switched off since, closed the fill-up valves, pressure now showing zero and no drip.
Assuming prv isnt working (!) and possible fault with fill-up valves (?)...question is - is it safe to turn back on and re-pressurise for showers etc until I can get an engineer in?!
Sorry for waffle...any advice appreciated....
