have a Baxi Combi Boiler. Shower yesterday suddenly only produces luke warm water no matter how high the thermostat is set, but water arriving in pipes is red hot.
Today the mixer tap in the sink seems to have a similar issue. Hot water comes through red hot then fades to luke warm even with mixer set all the way to hot.
checked kitchen mixer (tap nearest boiler). water is hotter but still not as hot as it was previously (ie i can bear to put my fingers under the stream of water which would have been scalding previously)
as this is now an issue on multiple points i can only assume it is a boiler issue - the hot water not strong enough when mixing with cold?
pressure on boiler is at 1 bar - where it has been for months and issue has only just occured so dont think that is an issue. No other changes been made to the system.
so far i have upped the water temp on the boiler (no difference)
increased pressure on system to 1.5 bar (no difference)
removed shower from wall to check water is hot (originally thought may be limescale build up in shower unit) water hot from the wall.
any ideas on the possible cause? solution?
