We have a Baxi 105E Combi boiler - 2 years old. Whenever the heating comes on, after a few minutes it begins to whistle, the noise is coming from the 3 way valve and it stops immediately as soon as you run a hot tap. Another symptom is that when you close the hot tap, there is a creaking noise then a light clunk from the boiler - this happens when and only when the heating is on. It started intermittently last winter but happens all the time now. The noise is piercing and getting louder as time passes. I read the previous entries in the forum and changed the washers on the wall jig connections ( the old washers were fibre the same as the new ones and showed no signs of incorrect fitting/damage). Also checked the washers & diaphragm in the 3 way valve and there's no splits/distortions.
Any ideas of how we can solve this problem
