baxi 105e
13 Feb 2007
Kent
i have got baxi 105e fitted, got the following problems
hot water sign stays on most of the time and when the sign is on the boiler keeps making loud noise. i have to turn the power off and back on again for noise to go off(thus, sound goes off for a little while and comes back again with the sign of hot water. please help.
Sounds like a faulty DHW demand switch!
What are you going to do now?
Tony
Probable faulty microswitch or the pin is not returning both on divertor valve . Brass thing on botom right hand side of boiler. Have a look and see if pin is out and touching microswitch when there is no tap turned on
