Baxi 105HE H/W & C/H problem
22 Mar 2007
Durham
The boiler will not always fire up to provide h/w and c/h when asked.
The digital control (wired) in the kitchen does appear to be working fine as it is asking when 'asked' for the c/h to fire up. The timer on the boiler also works fine.
When a hot tap is turned on the majority of the time you will not receive h/w. The boiler will show the green light on the neon but not fire up.
The pressure appears fine and there are no leaks.
There are no fault lights showing up.
I have tried resetting numerous times to no avail.
I have no experience with boilers and have just done what I thought was correct to give as much info as possible.
If you can help please do, it is getting rather cold now and the house on a night is rather chilly.
As said I have no experience with boilers but would like to know what is wrong first before I call out an engineer, money is very tight, as with most at the moment.
Thank you
