Hi just wondering if there is any baxi experts out there. I've had a real head scratcher with this boiler (105he instant) even the manufacturer's technical says there isn't anything more to check or change!
Here goes. Heating- fine ,pre heat function- Fine. no hot water. diverter valve is fine because the boiler rest in hot water mode and moves across for heating, which works.
open tap and the spindle doesn't move. The boiler will fire if you activate the microswitch so I'm thinking easy, diaphram. well it's not the diaphram, sensing tubes or where they lead too. the venturi, filters all cleaned out,and also the cold water inlet filter(easy 15ltr passing through). had a new pressure differential unit(the full part, diaphram assembly and rear unit that allows the pre-heat) put in and the spindle still doesnt move. technical says i've done everything i could do. So i'm thinking somewhere there must be a blockage on a pipe, any help would be appreciated
