baxi 105he leaking seal
6 Mar 2009
Leicestershire
I have a baxi 105he which has a weep on the DHW diverter valve where the pushrod enters the nut on the front of the valve.
This is not the first time it has leaked, I changed the o-ring & nut about a year ago, cleaned up the pushrod and it has started weeping again.
Does anybody have any advice, as far as I know,service kits only come as compolete diaphragm kits.
Can the o-ring be changed by just turning off the mains water supply & not draining the central heating system?
Thanks Very Much
Yep just turn cold off under boiler, also use silicone grease this helps keep it sealed
