I am looking at a Baxi 105HE. Customer had no hot water, as the main burner was cycling on/off due to heat build up. After some diagnostics I replaced the plate heat exchanger and the DHW diaphram, which cured the problem and the burner now stays on when hot water demand is called for and all burner pressures etc are spot on. HOWEVER??? when you turn a hot tap on now the water is barely luke warm (even though the burner is going at full rate, unless you turn on another hot tap in the house, whereupon the hot tap you originally turned on immediately goes hot and stys hot until you turn the other tap off, when it then reverts back to chucking out luke warm water again. Never seen anything like this before and would appreciate some ideas as I don't like a boiler beating me. (which I suppose it already has)!
