I have had the wiring replaced on my Suprima 40L with the Baxi 5111603 PCB replacement kit. It works for a while, 30mins to an hour before it locks out. I'm pretty sure its overheating.
Anyway I checked the fault code as per the manual (hold reset button for 10s, then count red flashes) but I'm getting 2 fault codes that don't appear in the user manual. These are
1. Goes straight to lock out, slow flash of red led, 3s on, 3s off.
2. Or, after holding reset button, 8 flashes within 10s.
As I said, neither of these fault codes are in the manual, only 2 and 5 flashes. I have been in touch with Baxi technical help and they don't know what the fault codes are either.
I was wondering if anyone else has come across these two faults and might know what they mean.
Stewart
Stewart
