Baxi 80/105 - Clicks but not always firing up
13 Dec 2009
Lancashire
Another problem with this 'great' boiler
Sometimes it doesn't always light first try, it clicks you can hear it clicking but no spark so no ignition, so eventually it shuts down with a fault
Turn the boiler off or press the reset switch and it then fires up normally, but then again maybe it won't
Other times you don't get the clicking as its trying to fire a spark
There is no set pattern to it not firing up first try, it can refuse to light 3-4 times in a row or it will light perfectly with no issues and then just decides not to light totally at random
Annoying and confusing
The three flashing lights that say it could be the PCB, but turn it off and wait a few seconds then it probably ignites as it should
Also the middle light flashes (60 light ?) on occassion when it refuses to ignite or click, again turn it off wait a few seconds or possibly a few minutes then try again and its usually fine, so that could point to a dodgy solder joint or component on the PCB .....
Weather its related to the issue with the pressure vessel either needing to be recharged or replaced I can't be sure until I get chance to look at that when I'm off work again in a day or so
What hasn't helped is the PRV used to drip, dropping the pressure, so the boiler would switch off
So I'm looking at possibly having to replace the pressure vessel if recharging it doesn't work, and also replacing the PRV anyway as that used to drip on a regular basis but appears to have stopped (unless its doing it sneakily now, still dropping pressure)
