I've got a Baxi 80 ECO. The 3 way pressure differential manifold sprug a leak from the front PTFE seal. I've changed the from assembly, no leaks everything looking good.
When you try hot water or heating, the fan kicks in, but no ignition and the second light on the panel switches to red indicating ignition failure after 30 seconds.
I've checked the overheat re-set, thats fine.
Any ideas would be 'warmly' received, I've got a horrible feeling it's a PCB fault ?
