Hi guys,
Im a first timer & have a question for you already.
My baxi 80 eco still runs the CH when its is not on demand. I am a sparky & have a bit of knowledge on the control side of CH. I have fitted a single channel timer & a stat.
When the fault first started I tested the timer & stat with all ok. I then had no link in the CH teminals & it still ran on. So the only way I can stop the heating is to switch off at the spur or turn the left hand dial to 0.
Is it a fault on the PCB which I could change or a part within the boiler.
Thanks guys.
Paul.
Thanks guys.
Paul.
