The Hw out tap does get hot as the pre heat store diminishes and then boiler takes approx 40sec to ignite to heat water up. As this happens the water goes cold.
Pre heat icon (tap) flashes even when stat is not in pre heat mode???
If i turn Hw stat off the pin retracts and when i turn stat up to either normal or pre heat the pin makes contact with microswitch, so that sequence seems ok.
Could the diaphram be perished or could it be more serious linked to PCB?
(havnt had time to chech diaphram yet)
Various threads on net seem to point to hw ntc thermister?....But this wouldnt keep pre heat function on when turned off at hw stat...Would it?
Hhhhhhhmmmmmmmm..........scratcy chin situation!!!!!!!!
