Baxi 80e Boiler Problem!
30 Nov 2007
Merseyside
Hi, I've got a fault on a Baxi 80e which is flasing 30 and 50 which is teh flame failure and Fault on Fan. I've changed the fan and still have the same problem :( Could it be a fault on the PCB creating a fan failure :confused:
A common fault on these is the pcb not sending power to the fan and the 50º light comes on.
So yes it is possible.
However you say that flame failure light flashes
If the fan runs the fault is usually further on in the ignition sequence, at the air pressure switch/ venturi or the gas valve.
There should be the odd baxi engineer on here later on that can be more helpful
Odd baxi engineer!
Don't ever recall seeing that combination of fault lights, so it's likely you have two faults or the PCB is shot.
Had the same fault on tues changed pcb been fine since.Hope this helps
