Hi all, I have an ongoing and quite frustrating problem with my Baxi 80E boiler. The DHW is working fine, but there is a fault on the CH side.
We have a timer and 'stat as per normal and these are both fine. The boiler fires if the temp is below the set on the 'stat and within the timer on window. It fires first time and heats up no problems. Rad's get hot and its ok. However as the boiler temperature drops and the boiler fires again to heat it the boiler will randomly cut out and stop firing. It will keep clicking the boiler to fire, which it will for about 10 seconds and then cut out again.
No warning lights on the front panel, but I changed the CH temp sensor anyways as I thought that may fix it and was only £15. I have spoken to Baxi and they want £300 for a call out and fix. My local 'specialist' was only interested in pulling it off the wall and fitting a new one !
Please help, going nuts now and cant find anyone 'helpful' without getting robbed blind ! Sorry for the long first post too !
