I have a Baxi 80e combi with a Towerstat RF/BM wireless programmer/thermostat.
All been plain sailing for a couple of years since the Towerstat replaced the old DIP switch module.
Lately, the boiler hasn't been responsing to the Tx unit. I thought it was a battery problem, but a fresh set didn't solve.
I figured it was interference, so I changed to Tx channel. No luck.
That problem magically stopped, as long as the Tx is close to Rx, to be replaced by a new problem, which is that once the heating has been on for a while and the radiators are only lukewarm, it just cuts out, and becomes unresponsive and a red light starts flashing ont he Rx module. If I press & hold the reset button and re-aquaint the Tx/Rx, then try again it works fine, only to cut out a few minutes later, and the red light starts flashing again.
This morning I noticed the pressure gauge was low, so I topped up the pressure, and it bagan working fine for a good 15 minutes, wand I initially thoguht because the pressure was low, it was overheating quickly and tripping out. But then it tripped out again! i'm losing my rag with this thing, and am beginning to think abiout replacing it all, as it is 10 years old!
I'm erring on the side of a Rx fault as having to have the Tx unit close by, and coupled with the red flashing light and having to reaquaint the two all the time. Either that or some thermostat has dies a death in the boiler itself.
Worth noting, the hot water works fine.
Any suggestions to get a new lease of life from my Baxi??
Cheers
JT
Cheers
JT
