baxi 80e lack of hw and leak from the gub screw on diverter
30 Apr 2010
Lincolnshire
hello can any help me i have a baxi 80e combi and i have luke warm water so i have replace the diafram and still not hot. diverter is working fine both pins go in and out but now i have a leak from the grub screw its just a small drip . any help would be much appreicate. :D
sounds as if its leaking from the main diverter body,its a new diverter valve im afraid :( straightforward to change tho if u have good access on the left hand side :)
ER no!!!!
Its sounds like its leaking via the 'o'ring and showing at the grub screw.
Also whilst your doing that. Whip out the plate to plate and clean out.
Plenty of info on here of how to clean heat exchangers.
is there a part number for this parts that i need and is it easy to refit them .oh thanks for all your help
kantago-where is this grubscrew located that u mean??
clf- leaking from wot "o"ring??
the grub screw i mean is located below dhw flow valve that keeps the flow valve attached to main diverter valve..... :confused:
