1st post so thanks for reading.
I have a 9 year old Baxi 80e driving a DHW and 6 radiator CH system. Recently I turned on the CH and noticed by chance the CH pressure gauge was at max 4Bar!!!! immediately I turned off the system and waited for the system to cool, pressure dropped. My observations were that the discharge pipe was not draining. On reading the manual i noticed that the PRV on this system should activate at 3 Bar, so surely this should have been working to reduce this over pressure in the CH system.
I also observed the pressure rose abnormally in the CH system, something to do with the Expansion vessel at the back of the boiler.
I also noticed that the CH pressure gauge fluctuated (increase slightly) when the DHW was operating. I thought the two circuits were separate so how could pressure be getting from one system to the other? Something to do with Plate Heat exchange from my research?
My thoughts on the issues are
1. The PRV has failed, it should open at 3 bar, so this needs replacing.
2. The expansion Vessel is failing, why would the CH pressure rise above normal operating pressure when at temperature.
3. The Plate Heat exchanger is somehow failing.
I have a professional coming on Friday to advise but wondered if i was on the right track ( I do like to have some knowledge of what is going on).
Many thanks for any advice
Andy
Andy
