Baxi Bahama 100-dropped presure now only COLD water
1 Apr 2004
Hello.
Weve got a Baxi Bahama 100 that about 6 months ago started leeking pressure. Girl called a plumber who charged her 50 quid to rase the pressure to normal only to have the same problem again.within days....out of order or what???
NOW the problem is that theres no hot water, we still have pressure in the taps but only cold water???? What to do and what could this cost to sort out..i mean a qualified guess wuold be appreciated...?
cheers for any replys!¬!!!
You have a leak on the system somewhere. It does not have to be a big leak to lose pressure. Could be on a rad valve even. If not, you may have to crawl about under the floor to find it. Could also be the pressure relief valve passing. Check this first. This is a 15mm pipe that should terminate outside the property. See if it is dripping. If all this is OK and you still do not have any hot water, it is probably the central heating flow switch. Please use a CORGI registered installer to carry out the work!!!!!!!!!!
Did you ever get this sorted? I seem to of suddenly got this problem.
What was the fix?
Thanks in advance
Dale
