- Joined
- 2 Mar 2004
- Messages
- 2
- Reaction score
- 0
- Country
The boiler stopped firing so I followed the flowchart in the manual which pointed at the two flow switches. I noticed that scale was emerging from the left hand one and it was dripping slightly. I unscrewed it (they're hand-tight), cleaned and replaced it - sorted the problem for a few weeks.
This morning the boiler won't fire again. The flowchart test is to use hot water only and if the boiler won't fire it must be the flow switch. I can hear everything else working OK so I suppose I need to replace one. The manual says they are a matched pair - the GCN is E02-764. Part number 241159. According to one supplier this part has been superceded by 240753. The suppliers seem to sell them individually, here for instance or here (select Bahama 100).
According to the manual, at least one needs a spring - does anyone know if both switches need springs as it looks like I'll have to order them separately?
Is there anything else I can test in case that doesn't fix it?
Thanks in advance
Chris
North London
Thanks in advance
Chris
North London
