BAXI BAHAMA 100
21 May 2008
Monmouthshire
boiler noisy on hot water only, on all hot taps, sounds like a plane diving, our water pressure is high but turning on a cold tap in an attempt to lower it makes no difference any ideas
You add it to the CH system water.
But X200 may be too mild to have much effect but its cheap and easy to do as a DIY.
You may end up having to have the HE changed ( CORGI job ) or professionally cleaned but few boiler engineers are very keen to do that.
We will do it but it is quite involved and messy and we charge about £180.
Tony
Tony
thanks will try what you suggest
Tony
did as you suggested added x200 boiler silent
thank you very much
