BAXI Bahama 100!!!
10 Feb 2007
Cheshire
Hi All,
My problem is, besides owning what i have discovered is the worst possible boiler in history!!!
My Hot Water does not work as it should it initially fires up and ignites the flames inside boiler but within a minute(about 25 secs usally it cuts out) and then after a couple of attempts it will not even ignite,this happen unless i have the heating on, in which case the water stays hot!
Any Ideas will be great !
There are lots of things to check, sensors, diverter, flow switches etc.
Its not a very easy boiler for many professionals so unless its something very simply you will probably need to call someone competent.
Tony
