Hi wonder if anyone has any ideas with a problem i am having with my boiler. It is a Baxi FS 801S RS.
On startup the gas doesnt seem to be igniting quickly enough. The gas hisses immediately, when i turrn the dial, and builds up and then finally catches (up to 30sec later) with a huge bang (like explosion). The boiler then runs fine until it reaches its temp and cuts of. when it needs to ignite again the same situation huge bang.
I have had an engineer replace the gas valve, the pilot light, the thermo couple and had the meter repaired to output the correct pressure. He also cleaned out the boiler and burners etc and set all correctly. He is totally stuck with it and I dont want to fork out for a new one as its working great apart from this problem.
UPDATE...................
when the boiler is cold and I turn on it ignites Perfectly no delay no bang etc. It's only when the boiler is hot and it tries to ignite that the explosion is occuring.
S.
S.
