Baxi Barcelona refusing to ignite. Thermistors, fan,system pumps condensate trap all check out. The boiler goes to the point of ignition but does not ignite the pilot. Just sits there making clicking noises about 10 seconds apart. Eventually locks out.
The ticking is approximately 10 seconds apart, It's a relay doing its job. I assume its the pressure switch. Gas is on demand is there, Just gets to the point where the pilot should light but it dosen't. No fast ticking of an ignition attempt.
