Good evening all,
I'm looking for some advice from someone that has installed Baxi's BBU HE15.
I have just installed the kit in a flat, read the installation manual at least 10 times and have no explanation from Baxi what the calibration controls are for & and more to the point why Baxi wouldn't explain what they are for in their manual.
These are the two control knobs behind the boiler cover that on on the Siemens PCB.
I have discovered that the left one is the water temperature control for the boiler - why why why doesn't the manual mention ANYTHING about this when it was set to 30 degrees from the factory.
Can someone tell me what the one on the right does?
I see some vague use on these knobs when setting the gas valve as per chapter 10 of the manual but quite honestly I'm clueless to what the right hand knob is for.
Other than that it appears to work a treat
Many many thanks.
Tom
Many many thanks.
Tom
