baxi bermuda 401 cut out circuit breakers
8 Sep 2008
Rutland
i fire up the central heating this morning,it heated the radiators for about 10mins then tripped the circuit breakers, i now dont have hot water /heat. i replaced a fuse(on a switch near the timer) but that keeps tripping the breakers again when switch on..any ideas :rolleyes:
I would check the pump first. Disconnect it electrically then try the power again.
could be pump, gas valve
once went to one that was leaking from the pipework onto the transformer for the fire....
