Recently the hot water from our back boiler has begun to heat up crazy hot. The hot water tank begins to vent after about 30 mins, the boiler doesn't shut off.
Central heating is fine.
When it first happened the pump began making some horrific grinding noises so I replaced that....but the boiler still didn't shut off and carried on over heating.
Next I replaced the 3 port valve and the cylinder thermostat. Still not shutting off.
Does this mean my cylinder thermostat isn't wired correctly?
or could it be the thermostat on the boiler? but then wouldn't I have the same problem with both HW and CH?
Many thanks for any help.
