Hoping for a miracle here folks as I know this boiler is ancient. We moved into our place a year and a half ago and haven't had any problems with the boiler either in terms of hot water or heating however for the last two days, we often get a "E110" error code. Looking at the instruction manual, it lists E110 as the following:
- E110 - Shows overheat of the primary water or excess condensate in the sump.
- E110 - Safety Thermostat or Condensate Safety Float Switch Operated.
I found a post on another forum where someone advised to check for air in the system. I went round all my rads and the magnaclean, there was a bit of air but we're still getting the same error after the heating has been on for 30 mins or so.
it's an old boiler so I haven't had much luck in finding anyone that will come out and take a look at it. Has anyone on here ever ran into this before?
Many thanks.
Many thanks.
