baxi bermuda cutting out.
3 Jul 2009
Cheshire
I have a baxi bermuda inset 2 backboiler that cuts out when you turn the roomstat up for the radiators to come on.We had the same problem about 9 months ago,so called an engineer who serviced it and couldnt find what the problem was,but when he had finished the service it was working fine again.He said it could have possibly been some dirt etc on a sensor.When the roomstat is off the boiler works fine just for the hot water,but as i say if you turn the roomstat up it cuts out after 60 seconds or so.
It could be a lack of water in the system. Heve you checked the F&E tank is about 100-120mm deep?
If thats OK it could be a blocked system or one of those anti syphoning valves.
Tony
