We have a very old baxi Bermuda back boiler and fire, and whilst not the most efficient boiler, does seem to run on and on.
Our annual use is very low for both fire and boiler as we heat our water by Immersion using our solar pv array, therefore, we do not want to spend lots of money on a replacement boiler and fire.
We have not had it serviced for some time now and I feel that if we are to keep it we should get this done, however, the wooden fire trim which hides all the ugly bits has been damaged so we have been using it without the fire trim.
I understand you must NOT operate the boiler without the actual fire attached as it is one unit but is there any problems operating it without the wooden trim cover?
I hope someone can help and give advice. We do have a fire guard to keep little hands away from hot parts.
Kind regards,
Andrew.
Kind regards,
Andrew.
